I would like to know how to download the fieldpoint software for fp-1000/1001.
I can't find any ways to download the fieldpoint software in "ni.com" and also "ftp.ni.com/support/fieldpoint/Server
(2,527 Views)
You will find the Fieldpoint Software, both firmware and drivers, in the Drivers and Updates section. Simplest way to navigate there is to follow the steps below. I also attached the URL at the end of this responce.
1. goto http://www.ni.com/
2. Under the Support category select the link to Drivers and Updates
3. In the Browse Option Select 'Current Software Versions'
4. Follow the first link for 'Distributed I/O - Fieldpoint'
5. You should now be able to download both the Firmware and the Hardware Driver for the FP-1000/1001.
Alternatively the direct URL is:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0E29?opendocument&node=132060_US
This should get you what you are looking for.
-Christer
(2,527 Views)
