I would like to know if i can share variable across internet through labview?
Hi, I am trying to learn how to share measured data across internet through labview so that it can be viewed and controlled offline. For this i have seen the G server configuration guide. Can i have a shared variable so that the data logged into this variable can be accessed and controlled through the other remote system. Further  can i have some theresholding operation on this shared variable to raise a alarm when the condition is satisfied.
If there is some reference document which can clear these issues then kindly post the same.
Regards
Shashi
Message 1 of 9
(5,684 Views)
Have a look at the "network published shared variable" available in newer version of LabVIEW.
Using the LabVIEW Shared Variable
Message 2 of 9
(5,680 Views)
Dear sir,
I have read the link which you have forwarded. I just want to reconfirm my understanding that if we want to share the variable using single process then we don't require any special hardware but in all other cases we need to have dedicated hardware. I would like to know that is sharing variable the most efficient way of passing values of a variable across Internet or there are some other methods.
If you can Kindly comment on this formulations of palletted for this link then it might be helpful. http://zone.ni.com/devzone/cda/tut/p/id/4385
With best regards
Shashi
Message 3 of 9
(5,642 Views)
You don't need any dedicated hardware. The variable engine can run on your local computer.
Message 4 of 9
(5,636 Views)
Dear sir,
As per mentioned in the document it has been said that the SVE can reside only in the PXI software in cases where we go for network Published variable. Kindly clear this doubt that won't it be required for me to have PXI hardware with sme configuration if i have to have SVE software in the PXI.
Message 5 of 9
(5,622 Views)
You're looking at the benchmarking section. Instead, have a look at figure 10 or Table 1 in the same article.
Message 6 of 9
(5,619 Views)
Dear sir,
I was able to generate the data and publish it across the internet but i used web publishing instead at present. Followed by it i could share variable data across two VI's on same computer. In this process i would like to know as in what would be the best way to export the data from this shared variable to an excel sheet. Will it be report generation toolkit or the indirect method. I would be happy if u can forward me some link which would teach how to do it.
With best regards
Shashi
Message 7 of 9
(5,602 Views)
Well i tried to publish data on local host but i am having difficulty in controlling the operation in the main system where i was running my VI. I am just able to view the data on the internet and cannot do anything with data.
Can you suggest something.
Message 8 of 9
(5,562 Views)
Hi DE,
How did u solve the issue of sharing Values between computers over the internet?
-John Theodore
Certified LabVIEW Architect, Certified TestStand Architect
Message 9 of 9
(5,302 Views)
