I would like to know if there is a vi that can substact 2 images, what ia mean is that u choose une particular pixel in 2 images, and labvieu makes the substraction of those 2 pixels
Thank you for contacting National Instruments.
Several methods exist for subtracting images. The method to use depends on the software you have available. If you have the LabVIEW Vision Development Module, either of the following methods will work:
  • Use IMAQ Subtract.vi, which is located in the Vision>>Image Processing>>Operators palette. This VI will allow you to either subtract two images or subtract a constant from an image.
  • Use a combination of IMAQ GetPixelValue.vi and IMAQ SetPixelValue.vi. Both are located in the Vision>>Vision Utilities>>Pixel Manipulation palette. With these VIs, you can subtract corresponding pixel values from two images, one pixel at a time. You would need to get the pixel
    values from the two source images, subtract them, then set them on the destination image.
If you do not have the Vision Development Module, your best option is to convert the image to an array using IMAQ ImageToArray.vi. This VI is located in the Vision>>Vision Utilities>>Pixel Manipulation palette. Once the image is in array form, you can subtract either the entire array or one element at a time.
Jesse D.
(2,641 Views)
