I would like to put the cursor in a certain position, is it possible ?
Hello, Good morning.
I would like change the cursor position ?
How can I do it ?
is it possible ?
Thank you .
Juscelino.
(2,994 Views)
Write the position to a proerty node of the graph. If you have multiple cursors, first select the "active cursor", thet write the "cursor position".
(2,985 Views)
Can you give me, please, a exemple ?
thank you
Juscelino
(2,968 Views)
There are plenty examples in the forum, for example here.
If you need more specific help, show us your code and tell us where you want the cursor.
Do you have a waveform graph, XY graph, intensitiy graph, etc.?
(2,965 Views)
Meavy you are talking about Mouse Position, in that case these examples could help you.
http://www.ni.com/example/27315/en/
https://decibel.ni.com/content/docs/DOC-2186
(2,950 Views)
