> The frame is a 240bit binary string that contains some 31 data points
> of varying bit width. bit 1=lsb and 240 =msb. transmission begins with
> lsb. the frame is such that some data points can be as short as one
> bit wide where the longest is 25bits wide. I looked at the array
> functions but they want to work in bytes, not bits. I saw one
> suggestion to flatten the string to a cluster and then bust the frame
> up in that manner. Not sure if that will do it though unless i append
> zeros anything less than 8 bits in width and turn the 25bit words into
> 32bit unsigned... this make any sense?
The array nodes work on elements. If the array is bytes, then they work
in bytes. If you truly want to work in bits, then convert to bits, the
n
use the array nodes.
I'm not sure if this is the best conversion, but wire the array of bytes
to a For loop. The loop will index the bytes automatically. Inside the
loop, wire up a conversion bullet to go from bytes to array of Booleans.
Wire this loop out to the edge of the loop, and this will make a 2D
array of Booleans. Outside the loop, you can use Array Reshape to make
a 1D array of the correct length.
With this you can index, split, or do whatever you like.
For a different but similar problem, you might want to look at the past
labviewzone challenge concerning bit twiddling.
Greg McKaskle
