I
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?I created some controls on VI .I want to move the control such that it is immediately below to tool bar.When i am trying to move the control to place on the top of the window scroll bar is also moving ? how do i solve this problem
Message 1 of 9
(3,999 Views)
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?Hi. You can select the control (or indicator) with the selection tool, and then use the arrows keys on the keyboard to move it where ever you want, as close to the top of the window as you want, or even outside the viewable area, without having to deal with moving scroll bars.
Hope this helps.
AlejandroZ
Message 2 of 9
(3,999 Views)
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?Hi,
This doesnot work .The space is still maintained as it is which i dont want.I want control to be place close to top of window .
Message 3 of 9
(3,999 Views)
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?What version of LabVIEW are you using? I am unable to reproduce your problem. If I move a control to the top, the window doesn't begin to scroll until the selection tool (the arrow) touches the tool bar and if I use the key keyboard, the scroll bar doesn't move at all. Even if it did move, why can't you just scroll the window back to where you want the control?
Message 4 of 9
(3,999 Views)
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?You can't stop the scroll bar from moving, that's just the way they work.
One thing you might try is placing the controls where you want them, then go into the VI Properties, select Window Appearance for the Catagory. Click the Customize button and uncheck the "Show Scroll Bars" checkbox. This will turn off the scroll bars while the VI is running. So they will still be there while you're editing the VI, but at least they will be gone and the panel not scrollable while it is running.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 5 of 9
(3,999 Views)
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?I am using 6i version.That is i use 6.0.Actually what i want is there should be no space between the tool bar and control.I mean i want the control just below the tool bar.But it is not coming always some space is maintained that is it is getting scrolled down when i am trying to move the control up.Hope u got my problem
Message 6 of 9
(3,999 Views)
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?am using 6i version.That is i use 6.0.Actually what i want is there should be no space between the tool bar and control.I mean i want the control just below the tool bar.But it is not coming always some space is maintained that is it is getting scrolled down when i am trying to move the control up.Hope u got my problem"
Message 7 of 9
(3,999 Views)
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?I think I understand the issue.
Try trowing some dummy controls on your front panel that are off-screen to the,
Top left
top right
bottom left
bottm right.
These should be outside you your viewing area with all otehr controls inside the boundry defined by the "dummies".
THese dummies will define the size of the FP at let you position your button as you choose. JUST MAKE SURE you button is inside the dummies. (Also watch new control that will appear below the rest).
Ben
Message 8 of 9
(3,999 Views)
created a control on VI .I want the control as a whole on to top of the window that is just below the tool bar.When i am trying to move the control the scroll bar is also moving.How can i place the control just below the tool bar without sroll bar moving?Here is a screen shot of a LV 6.0.2 front panel with some control right up against the toolbar and some are even partially hidden. I placed them there with the keyboard arrow keys and had no movement of the scroll bar or a gap. It would be nice if you could attach a screen shot of the problem as you see it.
Message 9 of 9
(3,999 Views)
