I2C Digital Waveform Library Timing Parameters
Does anyone know how the cluster of "I2C Timing (ns)" is being done in the following code?  It is an abridged version of the example VI "HSDIO I2C - Hardware Compare.vi" downloaded from here.  It uses the I2C Digital Waveform Reference Libarary.
The time on the X-Axis does not seem to be any help, and the front panel parameters are very cryptic in their naming system.  Does anyone know what all those numbers mean and how it correlates to the actual times (dt) between each point?
If someone helped you out, please select their post as the solution and/or give them Kudos!
(3,411 Views)
Accepted by topic author MrHappyAsthma
I finally found where the parameters are specified.  They can be found in the UM10204 I2C-bus specification and user manual.
Under the current revision 5, it is found in Table 10 on page 48:
(3,383 Views)
