I2C Lockup on cRIO 9045 module 9402
I have little knowledge of I2C communications and wonder if anyone can help explain / resolve a lockup issue.
I am using a cRIO 9045 with module NI9402 to communicate with a Sensirion SHT85 sensor. https://sensirion.com/products/catalog/SHT85  (powered by module ni9401). I'm using example code from I2C&SPI API  (attached below). This code is working with the sensor and I am able to get sensible readings of Temperature and Humidity.
If any cabling is removed from the NI9402 or the test software is stopped running and restarted on the cRIO I have issues regaining communication with the sensor. Each time the software is restarted the sensor is power cycled. The only way I seem to regain communications is if I completely power down the cRIO and restart it back up. I'm wondering if there is a away to avoid this and regain communications with the sensor programmatically?
I've tried a software reset via the code below (page 13 of the data sheet) by sending hex code 0x30A2 and that doesn't work. How would I enable an interface reset using the code below? I'm unsure if I am able to just toggle the SCL and keep the SDA high using the software available to me or if this will even resolve the issue.
(371 Views)
If power cycle the cRIO helps, how about creating a state to set all outputs to low, as if the NI-9402 is powered down?
https://tmesystems.net/
(319 Views)
