IAI driver
I want the IAI driver for controlling the P-SEL and X-SEL controller or code to control them, please help me.
Thank you very much
Message 1 of 9
(6,883 Views)
National Instruments currently does not have drivers for the IAI P-SEL and X-SEL controllers.  However, if you follow the link below to our Instrument Driver Network, there is a link to request a new instrument driver.  If you would like to request this driver, we will take it into consideration.  Thanks!
Message 2 of 9
(6,851 Views)
Yes, I want the IAI driver to control the robot in my factory, I am Electrical and Software Design Engineer in Tooling Design section which my
factory uses LabVIEW to controll all systems for production line, now I cannot use LabVIEW to control the IAI robot, please help me.
Thank you very much for your help.
Message 3 of 9
(6,841 Views)
No problem Smiley Happy.  If you havn't already done so, please follow the link posted above to request a driver.  You will need to fill out a form with detailed information such as the functional description of the instrument, and the instrument interface.  This form will be submitted to our Instrument Driver Group.  Please let me know if you have anymore questions, thanks!
Message 4 of 9
(6,831 Views)
Hi Meghen,
I had filled out a form already.
Thank you very much for your help,
Message 5 of 9
(6,803 Views)
Dear all,
Have you managed to control an IAI Actuator via LabView.
Could you please update me on that ?
Manhy thanks
Luís
Message 6 of 9
(6,176 Views)
luis,
I did some searching and, unfortunately, I was unable to find any published programs made by either user or NI employees to control an IAI Actuator.
Trey C.
Message 7 of 9
(6,153 Views)
Thanks for the reply.
Indeed, it's becoming a bit of a big task to control such piece of hardware via LabView.
Are you guys developing something right now for X-SEL from IAI ? Or should I give my input on the Drivers Section  ?
Message 8 of 9
(6,148 Views)
luis,
I am not aware of any development in this area.  Your best bet would be to, as you said, give your input in the drivers section.
Trey C.
Message 9 of 9
(6,139 Views)
