ICP I-7018 DCOM serial communication
I have some I-7018 modules connected to a I-7520 module (this module converts RS-485 to RS-232). They are wired correctly since with the software of ICP COM I can see the communication works fine.
The modules use DCOM communication, 9600baudrate, 8 data bits....
The problem comes with Labview. I made some simple .VI to write and read through the serial port. Then I create an executable of that .VI and run it in other computer. When I run any of the executables I never get an answer from the modules and I don't know why.
I tried several things:
- I have download from manufacturers web the DLL for labview...but they are really old (2004) and doesn't work on Labview 2016 and in 64bit PC.     http://www.icpdas.com/root/support/download/7000/7000.html
- I tried some different .VI to try to read an answer from the modules (see attached)
- I think I have installed all the drivers in the PC where I run the executables but i don't know if i'm missing something
(3,330 Views)
You say that you never get an answer when you run the executable. Are you able to test the VI from the LabVIEW development environment?
(3,242 Views)
