ICP algorithm in labview
Is there any module about ICP algorithm or about scan matching in labview?
(8,250 Views)
(4,673 Views)
I haven't personally seen a scan matching algorithm.  However, it is possible to build a library/dll (using something like PCL) and then call the library from LabVIEW.
(4,264 Views)
But I am working on a sbRIO which cannot call dll. What is the library you mentioned ? Can the library be used on sbRIO/cRIO?
Thank you.
(4,264 Views)
