ICP-con I7520 RS-232 to RS-485 converter
I'm looking for vi's that can work with the ICP-con I7520 RS-232 to RS-485 converter. The converter is connected to a ICP-con I-7018 thermocouple reader. I to downloaded the vi's from the ICP-das download webpage but this i don't succed to comunicate with this vi's to the instrument
(9,602 Views)
I often work with the I7520 and I use serial read and write vi's or the
software for the devices behind the I7520. This works very fine. So I
would search the problem round about the communication with the I-7018,
if you made sure that the wiring of the I-7520 is correct.
> to the instrument
(9,602 Views)
Please can you post the VI for write/read  I7520R  via serial port, i've been trying for days and can't do it !
(2,704 Views)
