ICPCON i-7540D command list to communicate over RS485
Hello All,
I am trying to communicate icpcon i-7043D (RS485, DO- digital output 16 ch) via icpcon (i-7540D Ethernet).
I can communicate with other COMports availabe (Using VxCOMM) e.g. COM1(RS232) COM3 (CAN). BUt I can´t connect COM2 (RS485).
Do anyone know how can I send command to this IcpCon 7-7043D ?
Regard´s,
Tejas
Tejaskumar Patel | (CLD)
(3,531 Views)
Hi Tejas,
first, I have to say i haven't heard of this manufacturer before, so all i can do is to give you some general advice.
I found these LV-drivers on their Homepage, normaly it should get the job done:
http://www.icpdas.com/download/7000/7000.htm
I havent tried them (since I don't own the hardware), but normaly you can just drag and drop them on your block diagramm, and it should work.
If you still experience issues with that, post some screenshots!
- Oliver
(3,505 Views)
Thank you Oliver,
For oyur time and reply.
When I use this driver I get response from hardware. But there are some more commands (http://www.icpdas.com/products/Remote_IO/i-7000/i-7043d.htm), which I cant use with this driver.
From my understanding its only possible via TCP Open & Write funtion but it didnt work.
Tejas
(3,487 Views)
Hi Tejas,
can you give me an example of a command that you cant use? All I could find behind the link was a list of specifications of the device.
If a command is not included in the driver, you can call a dll with the call library function:
http://digital.ni.com/public.nsf/allkb/F3009806E2AE416E8525645D0076B962?OpenDocument
If you understand german, or want to use a translator, you can find an in-depth-tutorial here:
http://www.ni.com/white-paper/4877/de/
the dll can be found on the same download page:
If that doesn't answer you question, please explain how you used the open&write func, and how it did fail.
Oliver
(3,468 Views)
