IComma / semicolon problem
I have a simulink model that i want to connect in LabView
No problem conection bye the SIT server, but Labview using comma and Simulink uses semicolon!! How can I get them to talk together, is't in simulink or labview i have to change my settings ??? and where can I do it?
(3,180 Views)
Hi
I really do not understand your question that well. Semicolons are used in Simulink to separate variables or to indicate end of command. The comma in LabVIEW is used as a decimal. I guess you are trying to create a user interface in LabVIEW for the Simulink model. Are you using the SIT connection manager? Are you getting any errors when using it?? Could you please elaborate your issue some more?
If you have not noticed there is a LabVIEW Simulation Interface Toolkit User Guide.
Regards
Mohadjer
NI-DK
Message Edited by mohadjer on 09-26-2005 03:22 AM
(3,154 Views)
I made a misstake posting this question, The problem I had was with decimal point! , vs .
But the Problem is solved!!!
(3,130 Views)
