*IDN? works in VISA test panel but VI does not
I can test my instrument connection with the VISA test panel:
But when I try this:
I get this error:
What could I possibly be doing wrong?
=== Engineer Ambiguously ===
Message 1 of 13
(8,537 Views)
Is this a RS232 or some other interface? Do not you need some sort of init before committing the IDN command with the VISA Write? Like VISA Open, or VISA Configure Serial Port?
Message 2 of 13
(8,514 Views)
It's connected through ethernet and uses LXI so like a GPIB instrument it has not required a VISA open since about LabVEW 8 or so.
Message 3 of 13
(8,504 Views)
If you quick drop, is that the constant you get for end of line?  I get one with a down arrow and enter looking thing (By picture, I'd assume eol/cr, but it's named end of line)  If you use this one, does it work?
Have you tried looking at the output string in a // codes string indicator?
Message 4 of 13
(8,501 Views)
Yes and this one (Line Feed) is the \n code just like the VISA test panel sends.
If it was the wrong terminator I would expect a different error, probably a timeout.
Message 5 of 13
(8,498 Views)
True.  I missed the error.  If you open up any of the VISA examples, I'd expect to see the same error if we're looking at addressing.  Do you?
Message 6 of 13
(8,489 Views)
I would try launching I/O Trace and compare the result from both cases.
Ben64
Message 7 of 13
(8,483 Views)
Not sure of this but I think that if you're using the VXI-11 protocol you need to explicitly open the VISA connexion.
Ben64
Message 8 of 13
(8,460 Views)
Ben64
1.  viWrite (TCPIP0::LCRY0614N49625::... (0x028B4920), "*IDN?.", 6, 6)
Process ID: 0x000006FC         Thread ID: 0x00002330
Start Time: 07:28:13.514       Call Duration 00:00:00.002
Status: 0 (VI_SUCCESS)
Buffer Contents
00000000:  2A 49 44 4E 3F 0A                                *IDN?.
2.  viRead (TCPIP0::LCRY0614N49625::... (0x028B4920), "*IDN LECROY,WR44XI-A,...", 1024, 42)
Start Time: 07:28:13.571       Call Duration 00:00:00.001
Buffer Contents
00000000:  2A 49 44 4E 20 4C 45 43 52 4F 59 2C 57 52 34 34  *IDN LECROY,WR44
00000010:  58 49 2D 41 2C 4C 43 52 59 30 36 31 34 4E 34 39  XI-A,LCRY0614N49
00000020:  36 32 35 2C 36 2E 38 2E 30 0A                    625,6.8.0.
3.  viParseRsrc (0x12B19590, "TCPIP0::LCRY061...5::inst0::INSTR", 6, 0)
Process ID: 0x000022E0         Thread ID: 0x00001CF0
Start Time: 07:28:20.144       Call Duration 00:00:00.000
> 4.  VISA Write ("TCPIP0::LCRY061...5::inst0::INSTR", "*IDN?.")
> Start Time: 07:28:20.160       Call Duration 00:00:00.006
> Status: 0xBFFF0011 (VI_ERROR_RSRC_NFOUND)
> Buffer Contents
5.  VISA Close ("TCPIP0::LCRY061...5::inst0::INSTR")
Process ID: 0x000022E0         Thread ID: 0x00001C38
Start Time: 07:28:41.512       Call Duration 00:00:00.001
I can see a couple differences, the main one being the VISA test panel DOES NOT USE VISA?
1-viWrite and 2-viRead are the VISA test panel, 4-VISA Write my VI and that is where the error occurs.
There is a couple subtle differences
I still don't know what to make of this.
Message 9 of 13
(8,429 Views)
Have you tried using VISA Open before the VISA Write?
Ben64
Message 10 of 13
(8,420 Views)
