IEC 60870-5 104
Hi
does any budy know how to use IEC 60870-5 104 function to read and write.
I have got a image at NI site http://sine.ni.com/nips/cds/view/p/lang/en/nid/210149
if any budy have have a example pls share
Regards
Sandeep
(4,990 Views)
Hi Sandeep,
You should have posted this question to the Industrial Communications forum. Few people in the general LabVIEW forums work with Energy Protocols.
To answer your question: Go to the C:\Program Files (x86)\National Instruments\LabVIEW 2012\examples\IEC60870-5\General folder. There is an example of a simple read and write there.
Jesse Dennis
Engineer
INTP
(4,906 Views)
Hi Jesse
Thanks for your reply.
I found  those example as you mentioned. but still facing problem for using them.
can u guide how to use those vi for simple read write operation.
Regards
Sandeep
(4,885 Views)
