IEC 61580 protocol
There are two methods of configuring Windows software applications to interact with the IEC 61850 protocol drivers
that also run on the Windows operating system on the rugged computer. one of them is DDE, how do i precise the
"item" at "DDE request" or "advise" that comes from IEC 61580 ?
(3,853 Views)
What driver for 61580 are you working with.  Currently, NI only has a driver for  IEC-60870-5-101 and 104.  Is this a third party driver, and what NI products are you using?  If you are trying to call a dll file from LabVIEW, then use the call library function node.
If you can give me some more info as to how you are using NI products, I may be able to assist you further.
Ryan
(3,831 Views)
TheGeeze
Hi Ryan
can u pls guide me how to use IEC-60870-5-101 and 104.
i found a example at NI site
Can u pls help me how to use function IEC-60870-5-101 and 104 to read an write.
If u can share any example it would be greate help to me
Sandeep
(3,473 Views)
