IEEE and LPT
Hello !
I use LabView 5.0. I get a task of management of the measuring device with
the help PC without IEEE488 and cable LPT-IEEE488. Whether there are any
drivers or ready VI, which allow to solve this task? Where I can find LabView
examples, which will help me to understand principles of organization of such
management?
Alex mailto:tumanovalex@mail.ru
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,990 Views)
Normally Windows environment does not allow to access hardware
directly. The only exception is access to I/O ports from within Win3.1
and Win95/98, but not on NT. As for LPT, only printing jobs are allowed
for normal apps.
As I remember LabVIEW has I/O access VIs but not sure. But if your
app need interrupt handling or running on NT environment, you need prepare
appropriate VxD (95/98) or Kernel Mode driver (NT), as well as its wrapper
DLL. Then your LV app can call the DLL through Call Library VIs.
Hope this helps
Makoto
Hello ! wrote in message <8d55n8$2h8$1@nnrp1.deja.com>...
>Hello !
LabView
such
>management?
>Best regards,
>Before you buy.
(2,990 Views)
