IF statement
Hi
I like to do the following statements in LabVIEW,
IF AoValue<=0.1 THEN
    AoValue1=(AoValue-0.0060)
    ELSEIF (AoValue >0.1) AND (AoValue<0.2) THEN
     AoValue1=(AoValue-0.0035)
ENDIF
Pls help with this
(4,046 Views)
Hi Veeru,
you can use a case structure to do that.
See the attached example.
Mike
(4,044 Views)
Use "Select.vi" from comparison palette and "And.vi" from boolean palette.
(4,044 Views)
Thanks Mike and Eugen
for ex if i want to do it for some 10 cases ,this program would be too long.
Is there any other method
(4,025 Views)
Yes, you can use switch-case structure instead of select.vi
Remember, you can write e.g. "1..3" for the case "1 to 3", or "..1" for the case "less than 1"
But you can't connect a double to the case-selector and compare doubles with decimal points, integers only.
(4,011 Views)
You can connect many data types to the question mark of a case structure.  You can connect a string, an enum, an error wire, boolean.  Here are examples:
Message Edited by tbob on 06-11-2008 09:47 AM
- tbob
Inventor of the WORM Global
(3,965 Views)
Thanks tbob
(3,933 Views)
