IFFT method
Please explain the method for performing an Inverse Fourier Transform (IFFT).
  1. How to plot the time axis (x-axis) after performing an IFFT.
  2. How to adjust the amplitude scale after the IFFT. If possible, please provide a .vi file.
(1,041 Views)
Hi kozuka,
  1. You already have time on X axis!?
  2. In which way do you want to "adjust" the Y scale?
After playing with your VI: you should use the IFFT function in pair with the corresponding FFT function!
(1,038 Views)
