IHow to force display of trailing zeros for fixed point numbers?
I have an 8 bit unsigned fixed point number, with 7 integer bits and 1 fractional bit, so the desired delta is 0.5. I want it to always display the fractional bit, even when that bit is 0. In other words, as this number is incremented, I want to see:
0.0
0.5
1.0
1.5
etc.
But instead I'm seeing:
0
0.5
1
1.5
etc.
I set the display format to Floating point, with 1 digit of precision. The "Hide trailing zeros" checkbox is NOT checked. What am I doing wrong?
I realize I could convert to single precision for display purposes to make this happen, but I'd rather make this work with fixed point.
-Ron
Message 1 of 13
(5,553 Views)
Ron
Check minimum field width and set it to match the desired number of digits of precision. Then select "Pad with Zeroes on Left"
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 2 of 13
(5,550 Views)
You should select 2 "Significant digits", and keep the "Hide trailing zeros"
untagged.
Wiebe.
Message 3 of 13
(5,539 Views)
VADave wrote:
Ron
I just tried that. It puts a bunch of extraneous zeros on the left, but does not show trailing fractional zeros.
Message 4 of 13
(5,539 Views)
untagged.
Wiebe.
I tried that. It doesn't show trailing zeros in the fractional part. In addition, once the integer part is 10 or above, the fractional part is no longer displayed at all.
I'm using LabVIEW 8.5, if that makes any difference.
Message 5 of 13
(5,529 Views)
I believe the settings you want are in Display format
Floating point selected in the list on the left
2 digits of precision
and don't hide the trailing zeros
Message Edited by yenknip on 12-05-2007 03:28 PM
_____________________________
- Cheers, Ed
Message 6 of 13
(5,525 Views)
I tried that. It didn't work. I get the same results as before. Theoretically, with your suggestion, I should see:
0.00
0.50
1.00
1.50
etc.
but I'm seeing:
0
0.5
1
1.5
etc.
When I select Advanced editing mode, the format string is shown as: %.2f
This works if I'm using single or double precision indicators, but not fixed point.
Message 7 of 13
(5,517 Views)
I just rustled up a VI with what I understand your input to be - unsigned 7 bit mantissa and 1 bit exponent input, and have it displaying 2 decimal places.... Is this what you're after or did I miss it?
- Cheers, Ed
Message 8 of 13
(5,505 Views)
That's not quite it. You're using a double (i.e. float) indicator. I want to use a fixed point indicator. My problem is that fixed point indicators don't seem to display trailing zeros in the fractional part, regardless of how their display formats are configured.
I'm wondering if that's because I'm doing something wrong, or is there a bug in LabVIEW?
Message 9 of 13
(5,492 Views)
With you now 😉
Yeah, it seems to be a bug in LV. decreasing the number of decimal places truncates the number, but increasing it does not add the trailing zeros.
It looks like you will need to display it as a single or double. Although if it is just being displayed to the user then I would just settle for that anyway.
- Cheers, Ed
Message 10 of 13
(5,487 Views)
