IMAGE RESIZE
Does anyone knows how to resize an image with labview?
(3,287 Views)
"freenao" wrote in message
news:8tuod5$3ic$1@news4.isdnet.net...
You can do it very easily programmatically. Work with a 2d array, find your
scaling factor, and using nested for-loops index at the source array and
output at the destination array.
Since your scaling factor will require floats, use some weighting algorithm
(look at the surrounding 4 integer pixels?) to figure out the value of the
float.
(3,287 Views)
