IMAQ Copy Overlay for images of different size
Hi Ppl,
I want to copy overlay from one image (Small) to another image (Large). Since the images are not of equal size the overlays from the smaller image always get copied on the top part of the larger image. Is it possible to copy these overlay with some offset specified on the larger image.
The above image shows the result of copying overlay from a smaller image to a larger image.
Is it possible to copy the overlay as above with some offset from the smaller image to the larger image.
Message 1 of 12
(5,302 Views)
With IMAQ copy overlay it's not possible to set the position.
What you could do is to take the rectangle of the first overlay, get the size of the first image and the second image, calculate the differnce in x and y and add it to the rectangle of the first overlay. This you can use than as rectangle for a new overlay for the second image.
Christian
Message 2 of 12
(5,288 Views)
Maybe something like the attached image..
Message 3 of 12
(5,286 Views)
Hi Christian,
Your idea will work fine. But in my case the source image (Small) has quite a few overlays (rectangles). So recalculating these rectangles and re overlaying become cumbersome. Thats why I was searching for a way to copy overlays with some offset specified.
Message 4 of 12
(5,271 Views)
I didn't know that you have more then one overlay. You are right, in that case it's a bit of work to do all that calculations and resizing.
But this is also the only way I know.
Christian
Message 5 of 12
(5,252 Views)
Hi everybody,
A few years later... is it still impossible to copy the overlay of a small image to a bigger one with an offset?
For instance, I process an image and I get overlay results (even without knowing exactly the overlay objects drawn) and I want to copy this image with its overlay in a bigger image at a specified offset...
IMAQ ImageToImage 2 seems not to do the job...
Lionel
Message 6 of 12
(4,632 Views)
you can suggest this is labview idea exchange
Message 7 of 12
(4,617 Views)
 I would happily do the necessary calculations, but I don't know how ot get the overlay results! I'm trying to move my clamp overlay results obtained on a cropped image back into the orginal image... but how?!
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 8 of 12
(4,416 Views)
I would say that you have to get numeric results from the tool and re-create a hand-made overlay result on your original image... Smiley Sad
Message 9 of 12
(4,400 Views)
Point being, the tool (clamp, for instance) applies an overlay but not the vectors. You are suggesting rewriting the tool? I just want the overlay vectors
_____________
Message 10 of 12
(4,381 Views)
