01-11-2011 06:09 AM
I'm using the Imaq GrayMorphology VI (in Labview 2009), and connected a control to 'operation'. This control shows more values than displayed in the help function. What are these other values?
Attached please find a print screen of the overview of 'operation' in the help function on the left, and all the values in the control on the right.
01-11-2011 06:22 AM
You can go to this folder : C:\Program Files\National Instruments\Vision\Documentation to find the Concepts_Manual.pdf, it contains lots of explications about the operations (page 9-10).
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
01-11-2011 07:02 AM
I found the details in IMAQ Morphology VI: (dear Labview people, maybe the IMAQ GrayMorphology VI should be updated to also contain this information)
| AutoM (0) |
Auto median |
| Close (1) |
Dilation followed by an erosion |
| Dilate (2) |
Dilation (the opposite of an erosion) |
| Erode (3) |
Erosion that eliminates isolated background pixels |
| Gradient (4) |
Extraction of internal and external contours of a particle |
| Gradient out (5) |
Extraction of exterior contours of a particle |
| Gradient in (6) |
Extraction of interior contours of a particle |
| Hit Miss (7) |
Elimination of all pixels that do not have the same pattern as found in the structuring element |
| Open (8) |
Erosion followed by a dilation |
| PClose (9) |
A succession of seven closings and openings |
| POpen (10) |
A succession of seven openings and closings |
| Thick (11) |
Activation of all pixels matching the pattern in the structuring element |
| Thin (12) |
