IMAQ ImageToArray returns NaN in LabVIEW 7.0
I wrote a VI to quantify an image using both LabVIEW 5.1 and IMAQ Vision 5.0. Recently I upgraded to LabVIEW 7.0. When I tried to run my VI, it worked well sometimes but very often, the data values were returned as NaN. Upon checking, I realized the problem lies with the IMAQ ImageToArray subVI. When I tried to convert an image to array, it sometimes return NaN. Can anyone help me with this problem? I am still using Vision 5.0.
Thanks in advance.
Kian
(3,354 Views)
Did you change the image format (there is a new image format in LV 7.0) ?
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,354 Views)
I would expect broken wires if this was the problem, but it is certainly a possiblility. If there is an image data type problem, run the image datatype update utility, which should be installed in the National Instruments\Vision\Utility directory.
There is also a high probablity that Vision 5.0 and LabVIEW 7.0 will not behave that well together. If this problem only happens occasionally, try and see if there is a correlation between the images themselves and the NaN values.
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(3,354 Views)
I don't seem to have the National Instruments\Vision\Utility directory. Do I need to install it?
Thanks.
Kian
(3,354 Views)
That is a directory that may not be on your system due to the version of IMAQ Vision that you have.
I have attached the LLB to this post in case you cannot locate it.
Colin C.
Blog
(3,354 Views)
