IMAQ Pattern Match Score
I am working on an application that uses the IMAQ Match Pattern VI.  The matches that are returned have a score assigned to them.  The help documentation for this reads:
Score ranks the match results on a scale of 0 to 1,000, where 0 equals no match and 1,000 equals a perfect match.
Likewise, there is a VI input called "Minimum Match Score", which is the smallest score a match can have to be considered valid. The data range for a match is between 0 and 1000.
Can anyone point me to a resource that might better explain how this score is derived or at least defined?
(3,668 Views)
The NI Vision Concepts Manual provides ancillary information; I've linked that below. The In-Depth Discussion for both Pattern Matching and Geometric Matching may prove helpful in providing the detail you're wanting.
Machine Vision:
http://zone.ni.com/reference/en-XX/help/372916P-01/TOC15.htm
I hope you find this information helpful. Have a great day!
- Kale
(3,630 Views)
