IMAQ Read file 2 .vi error -1074395992
Hi
The application is running continuously with IMAQ read file 2 .vi without any errors.But in between error no. -1074395992 is occuring while reading the image file.
It would be helpful if any one can help with this error.
(2,282 Views)
You can right click the error code and choose Explain Warning.
(2,241 Views)
hi
so what could be reason for "File access denied"?
(2,222 Views)
Hi Sajeesh,
Some other routine or application is accessing the same file in parallel…
(2,219 Views)
Hi GerdW,
so in LabVIEW do we have functions or libraries to check if the file is used/accessed by other applications.
(2,184 Views)
