IMAQ Select Annulus Resize
Hello guys! I have a problem in Labview because when I use the function IMAQ Select Annulus, the Image out is very large. How to change the dimensions of this. Can I use Zoom to fit? I put the photos with my Vi.
(1,331 Views)
Try using a window value between 0..15 instead of the default -1.
This way the pop-up window seems to remember its previous size and zoom level.
(1,262 Views)
