IMAQ SetColorPixelValue
Hi, I have a 2x2 pixel jpeg file and I want to change the RGB color of each pixel. I am using the SetColorPixelValue function. After doing it I save my file in jpg format, but each pixel has a different color that the color I want. Is this a bug of the LabView v7?
Thanks.
(2,928 Views)
You should use IMAQ ColorValueToInteger function to compute the U32 that goes into pixel value terminal. Let me know if you trouble using that as well.
Yusuf C.
Applications Engineering
(2,928 Views)
