IMAQ Threshold Image
HI All
I am trying to apply a threshold to an Image so that I can track its centroid across a screen as a beam moves, the goal is a beam pointing Stabilization.
I have set the threshold to be between 128 and 255. The vi description seems to suggest that I anything between these two values would be set to zero but it seems to do the opposite (Anything outside this range is set to 0).
Would anyone be able to assist me in understanding how this works.
Best Wishes
Andrew
Message 1 of 19
(3,833 Views)
maybe just an issue with the Intensity plot...?
Message 2 of 19
(3,795 Views)
Hi
Thank you so much for the reply, would it be a good idea for me to send you the VI so you can have a look at it.
Best Wishes
Andrew
Message 3 of 19
(3,792 Views)
@AndrewIons01 wrote:
Hi
Best Wishes
Andrew
save your .vi with  typical data(you have to click edit>make current vales default)
and then attach to this post
Message 4 of 19
(3,761 Views)
Thank you for replying, Here is the vi
Message 5 of 19
(3,758 Views)
I am afraid there is no data (in your 4dsigma Threshold example.vi ‏62 KB)  attached - also, maybe the issue is in your self-written sub.vi?
Message 6 of 19
(3,746 Views)
Sorry for the delay, here is is. I ma also having trouble taking a series of images, computing them into 2D arrays, taking the average of these arrays. I keep getting zero at the moment.
Message 7 of 19
(3,720 Views)
I'd do something like this
Message 8 of 19
(3,708 Views)
Thank you for the reply, I do have a question regarding your solution, why do you have two graphs going into an array builder? why do we need both going in.
This image is a grey scale image, can set the colours to be a grey scale automatically?
My final question (its a silly one). How does this function compared to the IMAQ Threshold VI.
Once again I appreciate your help.
Andrew
Message 9 of 19
(3,694 Views)
Hi Andrew,
Because both graphs are set to the same properties…
Yes. just change the colorscale settings (aka ZScale.MarkerValues)…
Message 10 of 19
(3,691 Views)
