IMAQ_USB_Init.vi error -1074396024
Hey PincoG,
You need to have at least the Run Time Engines of LabVIEW and Vision. And because the NI-IMAQ for USB driver uses some of the NI Vision Development Module functions, you will need to have the Vision Deployment Engine on your deployment machines. You will have to purchase the licenses for the Vision Deployment Engines for each machine you want to use the NI-IMAQ for USB on. Contact your NI Sales Rep for further information about that. Let me know if you have further questions and let me know if this doesn't work. Thanks, and have a great day.
DJ L.
Message 11 of 12
(2,303 Views)
Hey Cheeaun,
The NI-IMAQ for USB Cameras is a free software driver for acquiring images from any DirectShow imaging device into LabVIEW. If your USB TV Adapter is not DirectShow compliant, then the NI-IMAQ for USB driver will probably not be able to acquire images using it. Just because Windows can detect the USB camera, and the I-Vision software can acquire from it, does not mean that the NI-IMAQ for USB driver will be able to detect or acquire images from it.
The best way then to acquire images from a non-DirectShow USB "camera" is to use the DLL that comes with the hardware, and use the LabVIEW Call Library Function Node to access that DLL. This is kind of like making your own USB driver for the tv adapter. Most often, 3rd party DLL's will return the video data as a 2-D array of pixel data. You can then use the Vision Development Module function called IMAQ ArrayToImage.VI to convert the array of video data into an image data type to be used to display images in the Image Display.
I hope this helps. Please let me know if you have any further questions or concerns. Thanks, and have a great day.
DJ L.
Message 12 of 12
(2,301 Views)
