IMAQ USB ON LABVIEUW 2009
hi,
I downloaded Imaq usb driver to use it with LV 2009 student and vision, on LV 8.5 (other pc) it works fine, but on LV 2009 there are no usb pictograms available in the vision menu, the other vision vi's are available.
OS: win 7 and win xp ( won't work on both)
Jeffrey
(2,860 Views)
Accepted by topic author Jeffrey_Prinzie
Hi Jeffrey,
Starting with Vision Acquisition Software 2009 we integrated the IMAQ USB Support in IMAQdx.
So you should be able to use IMAQdx functions for grapping images from USB Cameras, but keep in mind the need to bei DirektShow compatible.
In former Versions ther was a sepperate Installer for IMAQ USB, that's right.
Hope this helps,
Christian
(2,843 Views)
So shouls i download IMAQdx and install it, i can only find IMAQdx 8.5, Now, with the vision acquisition software 2009 installed i can use the functions (4 tabs) to edit and proces the image but no usb connection.
Jeffrey
(2,822 Views)
Hi Jeffrey,
Using LabVIEW 2009 you will also need the Vision Acquisition Software 2009 or the Vision Development Module 2009 which also contains all the processing functions, but both will need to be activated. So simply downloading gives you the 30day evaluation period, but then you will need to buy it.
Christian
(2,788 Views)
