IMAQ USB for LV2009
I updated Labview from 8.6 to 2009, with Vision.
After installation of ni-imaq-usb library (August 09 version), USB Acquire Image is available in Vision Assistant 8.6 but not in Vision Assistant 2009. Same issue in the Control when I code in the back panel.
Furthermore refering to 8.6 librarie when coding in 2009 make close the vi and Labview 2009 without any explanation.
Is there a version of IMAQ for USB available for Labview 2009?
Message 1 of 8
(6,744 Views)
Hi, I have the same problem!, have you solved it?
AmG
Message 2 of 8
(6,739 Views)
hi again,
I have found this:  http://forums.ni.com/ni/board/message?board.id=6170&message.id=11182
it's in spanish, but the important thing are the links inside.
check it, i'm downloading it.
AMG
Message 3 of 8
(6,735 Views)
Accepted by topic author Tanguy Le Corre
With the 2009 release, IMAQ-USB is now part of the NI-IMAQdx driver in the VAS 2009. Download it from this link:
NI Vision Acquisition Software 2009
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 4 of 8
(6,716 Views)
Adnan is correct-USB camera support is covered by the NI-IMAQdx driver as of Vision 2009.
One thing to be aware of is the fact that the NI-IMAQdx driver does require a license.  If you have the Vision Development Module, the license for NI Vision Acquisition Software is included.
Alex Person
NI-RIO Product Support Engineer
Message 5 of 8
(6,702 Views)
Thanks for the Imaqdx informations, now the cameras are listed by Imaqdx Enumerates Cameras.vi, but IMAQdx Get Image.vi produce the error: " Invalid pointer". I tried with one creative webcam and one usb frame grabber. I both installed their own drivers after installing Vision Acquisition 2009, it's possible to acquire with their own softwares.
And in Vision Assistant 2009, in the Acquire tab, the first item Acquire Image is unavailable and tells me "no image acquisition device is curerntly installed in your machine." The other Acquire Image items (IEEE 394, RT ...) are available but no cameras of these types are installed or plugged. This fact goes again Imaqdx Enumerates Cameras.vi, but the result is the same: it doesn't work.!
Message 6 of 8
(6,693 Views)
My bad, the USB cameras are recognized as IEEE 1394 or GigE in Vision assistant.
Message 7 of 8
(6,689 Views)
My bad again, I forgot to initialize my image.....
Problem solved!
Thank you all
Message 8 of 8
(6,686 Views)
