IMAQ USB on Windows Vista
Hi AnthonV,
You are right that the Vision Run-Time Engine will be sufficient to run IMAQ for USB.  This is a different requirement than other IMAQ drivers however, which do not require Vision or the Vision Run-Time Engine to execute.  You should note, however, that the Vision Run-Time Engine also requires a license to activate.
Wes P
Wes Pierce
Principal Engineer
Pierce Controls
Message 11 of 25
(2,597 Views)
I am getting the same error code on a XP system and VISTA system by the examples (imaqUSB examples),by means of vision library functions (LabVIEW 8.5 FDS, Vision 8.5)
Message 12 of 25
(2,566 Views)
Hi Weiwb,
Have you tried inserting the Vision CD and installing support for LabVIEW 8.5?
Wes Pierce
Principal Engineer
Pierce Controls
Message 13 of 25
(2,550 Views)
I have you  installed support for LabVIEW 8.5,But I  am getting the same error code on a XP system and VISTA system by the examples (imaqUSB examples)
Message 14 of 25
(2,484 Views)
Hi weiwb,
Is the camera that you are trying to use DirectShow compliant?
Wes Pierce
Principal Engineer
Pierce Controls
Message 15 of 25
(2,472 Views)
Logitech QuickCam
Message 16 of 25
(2,453 Views)
Hi weiwb,
What are the errors that you are getting, specifically?  Also, when do they occur?  It sounds like what you are seeing might be different from what has already been seen on this thread.
Wes Pierce
Principal Engineer
Pierce Controls
Message 17 of 25
(2,424 Views)
was the same error message (-1074396024)
Message 18 of 25
(2,415 Views)
Hi weiwb,
When do you get this error?  At installation?  At run-time?  Also, you might try uninstalling and then reinstalling IMAQ for USB.
Wes Pierce
Principal Engineer
Pierce Controls
Message 19 of 25
(2,395 Views)
Message 20 of 25
(2,215 Views)
