IMAQ Vision Error- 1074396120 Not an image - Unsolved
I had a code that worked without Errors. I then incorporated enqueue/dequeue elements and I have this Error pop up (see attached):
I am not sure if the QUEUE functions connections are correct, in order to track down why this error occurs. But I am pretty sure that IMAQ write is fine, as it worked earlier and I have checked within the IMAQ write sub-VI to confirm that it is as it should be (as earlier when it worked).
I attach the VI and a print screen showing the pop up error.
Any advise?
Much appreciated!!
(3,351 Views)
Can you share a LV 2012 version of the code?
Thank you.
regards
aveo
(3,232 Views)
Hi aveo, Did you check when was the last time user visited this forum?
-Even i don't have lv13 to downconvert and give the code.
-If you want may be post the vi in this http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
-But from image, it is clear that he/she should have taken image from Dequeue and not from other loop.
-If you have any other problem, start new thread for more visibility and post your vi or screenshot to explain problem.
uday
(3,224 Views)
