IMAQ Vision on Linux
Can I run IMAQ application using LabView for LINUX?
(4,203 Views)
Not, yet, nor any time soon probably. But call NI and tell them that you are interested in support for Linux.
-Jim
(4,200 Views)
LabVIEW can access most drivers pretty easily. At this time, though,
many of the I/O drivers aren't available on linux. If you were talking
about NI IMAQ the answer it no, not unless you want to write some of
your own driver SW. If you have an IMAQ board and driver for it on
linux, then the answer is yes, you can call that from LV.
Greg McKaskle
(4,200 Views)
I have an IMAQ-PCI-1411 capture card and I've planed it to be used on Linux OS. Seems this question have been asked a few years ago, I just want to know if there is new updates on the support for Linux OS.
One more thing, is it any other capture card either analog or digital that available to be used on Linux OS?
Thank you.
Message Edited by kamil on 08-08-2006 01:39 AM
(3,997 Views)
There is still no IMAQ support for Linux or Mac's as well.  The more product suggestions that are made throughthe Product Suggestion Center on ni.com for IMAQ support in Linux, the better.  Here is a link to the Product Suggestion Center :  http://digital.ni.com/applications/psc.nsf/default?openform
Jason N
(3,985 Views)
