IMAQ WindNonTearing does nothing
I found an answer to a previous question about using IMAQ external display non-tearing mode as a solution for video tearing for live display. However it does not appear to work on the computer I am using.
http://forums.ni.com/t5/LabVIEW/IMAQ-WindDraw-isn-t-working-with-multiple-displays/m-p/1546912#M5721...
If I use the non-tearing option nothing changes. The program works but tearing occurs regardless of the setting on tearing or non-tearing. Another higher speed application testing this feature also shows screen tearing regardless of setting.
I am trying to display live captured video on the front panel but the screen tearing is distracting and compromises the video as it is intended to be used in a semi-automatic inspection.
I am running on windows XP SP3 (nvs 300)
(2,762 Views)
Hi riakar,
I tried running the example from the attached post and did not have issue issue or screen tearing could you post your vi?
Joe Daily
may the G be with you ....
(2,744 Views)
