IMAQ WindUserShow
I am upgrading a real-time image analysis program from LabVIEW 6 / Vision 5 to LabVIEW 7.1 / Vision 7.1.1.
It seems that the user-defined toolbox window VIs have disappeared from Vision 7, but are still included
in the compatibility library in Vision 7. The problem is that (at least on my system), The IMAQ WindUserShow
VI crashes LabVIEW. The LabVIEW process stops responding when the VI executes and Windows only allows
me to kill LabVIEW.
So, a couple of questions. What has happened to the WindUserXXX VIs? If these VIs should no longer be used, what
is the recommended way of implementing user toolboxes, other than the built-in region tools? Is there
any known solution to WindUserShow crashing LabVIEW 7.1?
Mikk
Message 1 of 1
(2,686 Views)
