IMAQ Zoom
Using the IMAQ Tools provided by IMAQ ConstructROI one can zoom images, but I couldn't find a way to get the zoom factor out to apply it to other display windows. Is there a hidden way to do this ?
(3,280 Views)
Please elaborate. Are you trying to zoom on other IMAQ display windows, or just other windows?
If it is for other IMAQ display windows, then all you do is set the zoom factor based on the window number you are trying to zoom.
If you are trying to use it for other, non-imaq windows, this is not possible.
(3,280 Views)
I want to apply the zoom factor once chosen to all other IMAQ (!) display windows. If you use the magnifier in the WindTools-Palette when you draw ROIs you can zoom your image - but I found no way to reuse this zoom factor automatically in all other IMAQ displays...
(3,280 Views)
