IMAQ compatibility PCI board
I'd like to know if it's possible to use others PCI video acquisition boards with IMAQ functions?
If true, could you give me a list of compatible manufacturers?
Thank you in advance
Bim
(3,062 Views)
please...
(3,048 Views)
Bim,
I found this link on NI's WEB site that may help you.
http://ohm.ni.com/advisors/board?productFamily=Image%20Acquisition
You can use any board as long as you can "talk" to it using LabVIEW.  I use a board that has a full set of ActiveX controls that I use to acquire the image and save it to disk.  I then use IMAQ Read to read the image into IMAQ format.  Once it is in IMAQ format you can do anything to the image.  A bit cumbersome but the only option I had.
I would further recommend that if NI has a board that you can use then use it.  You are not going to make things any easier by using a third party board.  The NI boards do cost more but integrate easily into the test system.
Matt
Message Edited by mfitzsimons on 10-12-2005 01:21 PM
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,038 Views)
You can use driver NI-Imaq only with National Instrument Board, because this driver has been created for N. I. Board.
You can use Ni-imaq for IEE1394 for camera that can be connected in IEE-1394.
See this link below to see wich camera is supported :
You can use NI IMAQ VISION Tools for make analyse of you bitmap.
Christophe
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(3,017 Views)
Christophe,
Not sure where you are going with this but I will try to answer.  If you are using a 1394 Firewire Card it doesn’t have to be NI’s.  It does need to be:
Fully supports version 2.0 of the IEEE 1394 standard for high-speed serial bus communication
100% compliant with open host controller interface (OHCI) requirements
You want to use .BMP files only for vision analysis because they are uncompressed.  Using a compressed image file like .jpg or .png will cause unexpected results.
Matt
Matthew Fitzsimons
(3,011 Views)
Hi Matt,
Sure, it's right, you can use NI-imaq for IEE-1394 for any camera if they are Fully supports version 2.0 of the IEEE 1394 standard for high-speed serial bus communication.
Christophe.
Christophe S.
(2,998 Views)
