IMAQ is not working with LabVIEW7.0 upgrade- sub vi files in the wrong location?
I have installed an upgrade to LabVIEW 7.0 Base Version (from LabVIEW 6.0) and now my programs that involve IMAQ are not working. I receive a warning that the sub vi's involving the IMAQ Writefile are not in the expected location (in the Vision file library). Even if I try to load IMAQ Vision 7.0 the same problem still occurs. When I look at the program, the image in and image out leads to the IMAQ image capture vi's have changed from a pink to purple wire type. When the program tries to find the WriteFile.vi it pulls it from the old version instead of an updated vi, and these wire types are not compatible. Do you have any suggestions of how to solve this problem?
(2,502 Views)
Thank you for contacting National Instruments. Your problem sounds similar to the one discussed in the following knowledgebase. Let me know that doesn't fix your problem.
http://digital.ni.com/public.nsf/websearch/03455A3CE6F8869F86256D2F006E6A66?OpenDocument
Yusuf Cavdarli
Applications Engineering
(2,502 Views)
