IMAQ property node
taroK,
If possible, can you please change the bitstream in your camera file.  You should try changing the following line: AcquisionBitstream(.dat) to any one of these;
CL_TC1T64_RGB-Class07.dat - Ten, 12, 14, and 16-bits per color plane RGB tap configurations. Only one tap.
CL_TC10T8_1X10-Class07.dat - Eight bit, with ten zones in X, and one tap per zone, such as the Basler A504k (most common for ten-tap tap configurations)
CL_TC10T8_1X10_Alt1-Class07.dat - Eight bit, with ten zones in X, and one tap per zone, but with the Vosskuehler bit mapping, such as the Vosskuehler CMC-1300 or CMC-4000, or Allied Bonito CL-400B/C (very rare)
CL_TCxT8_1Xx-Class07.dat - Eight bit, with one zone in X
CL_TCxT16_1Xx-Class07.dat - Ten, 12, 14, and 16-bit, with one zone in X
CL_TCxT8_xX1-Class07.dat - Eight bit, with multiple zones in X, but only one tap per zone
CL_TCxT16_xX1-Class07.dat - Ten, 12, 14, and 16-bit, with multiple zones in X, but only one tap per zone
CL_TCxT8_2XxE-Class07.dat - Eight bit, with two zones in X, one or two taps per zone, and a line-ends extraction direction in X.
CL_TCxT16_2XxE-Class07.dat - Ten, 12, 14, and 16-bit, with two zones in X, one or two taps per zone, and a line-ends extraction direction in X.
CL_TCxT8_1X1_xYx-Class07.dat - Eight bit, with one zone in X, one tap per zone in X, and either multiple taps in Y, or multiple zones in Y.
CL_TCxT8_xXE-Class07.dat - Eight bit, with an even number of zones in X, one tap per zone, and a line-ends extraction direction in X
CL_TCxTx_Base-Class07.dat - Supports all Base tap configurations (24 data bits, one Camera Link cable)
T_TCxT8_1Xx-Class07.dat - Eight bit, with one zone in X. Uses the internal TestImage instead of the Camera Link pins
T_TCxT16_1Xx-Class07.dat - Ten, 12, 14, and 16-bit, with one zone in X. Uses the internal TestImage instead of the Camera Link pins.
This might expose different behaviors than the hang. There is a long list of .dat files in NI Camera File Generator.ini available which you can also try.  Failing that, could you please switch DVALMode(1) to DVALMode(0) and give this a try also.  Please let me know how it goes, and if you have made any progress on your end.
I know that camera files have to be quite specific so it may be quite tedious but this is the most likely source of the problems you are having.
Robert Ward
Applications Engineer, NI
Message 11 of 15
(1,573 Views)
Sorry for the late reply. I finally tried all of the dat files, and they did not make any diffenrence.. DVALMode did not change anything, either. I am going to ask the camera company about the camera file.
Message 12 of 15
(1,548 Views)
I am sorry, but I realized I changed a wrong line in the camera file. I changed the settings for ni-1429, not ni-1433.
Then, I just tried to change the AcquisitionBitstream setting from Class07.dat to others, but MAX complained that it did not find them..
Message 13 of 15
(1,540 Views)
The camera company suggested this may have something to do with the driver of the frame grabber. I imagine the program runs 32 bit even though I am using 64-bit Labview?? I installed the latest IMAQ and it supports 64-bit Windows 7, but the whole issue does suggest some memory problem.
Message 14 of 15
(1,525 Views)
Dear taroK,
That information is very helpful.  You should be using LabVIEW 64-bit, because it has a maximum memory limit of 192GB, whereas 32-bit has only 4GB ( http://www.ni.com/white-paper/10339/en ).  The ActiveX controls are configured in 32-bit, so generally it is advisable to use 32-bit unless you are getting through insane amounts of data - which you are doing.
The IMAQ is a native 64-bit driver precisely for the kind of application you are performing, and the framegrabber has a 512MB FIFO with 850MB/s bandwidth and you are generating 669.6MB/s through your camera.  Personally; I thought all the memory calculations worked out, which was why I thought it is something else such as the camera file settings.  But the fact that your program slows down when toy change from 1 second to 6 seconds of acquisition definitely points to it being a memory issue.
Was there an option when you installed the IMAQ drivers/ NI Vision of the option 32- or 64-bit?
Robert Ward
Message 15 of 15
(1,521 Views)
