11-09-2005 11:56 AM
11-10-2005 12:08 PM
These VIs install with the IMAQ driver. IMAQ 3.5 (for LabVIEW 😎 can be installed from the LabVIEW 8 Device Driver CD. Once you install IMAQ with support for LabVIEW 8, the VIs will show up in the "Function » Vision & Motion » Vision Utilities » Files" palette. Take care!
Aaron B.11-17-2005 09:47 AM
11-18-2005 12:13 PM
To place a subVI on the block diagram of another VI, simply choose "Select a VI..." from the functions palette. You can then navigate to the subVI and select it to be inserted. There is an entire section of the LabVIEW Help devoted to creating and implementing subVIs. I would definitely recommend reading through that section to learn more.
Kind Regards,
