IMAQ: recognize circular and triangular pattern
I am working on a project where I am getting a pipe as input picture. The background and lightning can vary and its hard to get the same image over and over.
I would like to get the Y position of the triangular and circular phase on the pipe.
In the PNG file you see:
Figure A:        Typical source picture
Figure B-E:    Different results after filtering source picture
Is there some way to recognize the phases outlined in red?
I am new to pattern recognition and can't find any good examples for this task.
(3,266 Views)
Yes, it is possible to detect the geometries outlined in red. For example you could use edge detection within a Region Of Interest, or a Geomatric Matching. For more informations on the algorithms please view this KB article:
IMAQ Vision Algorithms
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9ouSAC&l=en-US
I'm also adding a KB on geometric matching:
Why Wouldn't the Selected Template Match with the Main Image When Using Geometric Pattern Matching?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Kx0SAE&l=en-US
and finally some community examples with vision and detection / matching:
Continuous Edge Detection Using Morphological Filters
https://forums.ni.com/t5/Example-Code/Continuous-Edge-Detection-Using-Morphological-Filters/ta-p/352...
Edge Detection with a USB Camera
https://forums.ni.com/t5/Student-Projects/Edge-Detection-with-a-USB-Camera/ta-p/3529424
Verify Wires: Vision Builder AI
https://forums.ni.com/t5/Example-Code/Verify-Wires-Vision-Builder-AI/ta-p/3508056
Identify "Perfection" Piece Using Geometric Pattern Matching
https://forums.ni.com/t5/Example-Code/Identify-quot-Perfection-quot-Piece-Using-Geometric-Pattern/ta...
Identify Multiple "Perfection" Pieces Using Geometric Edge Matching
https://forums.ni.com/t5/Example-Code/Identify-Multiple-quot-Perfection-quot-Pieces-Using-Geometric/...
Simple Face Detection using IMAQ
https://forums.ni.com/t5/Example-Code/Simple-Face-Detection-using-IMAQ/ta-p/3525705
Use Vision Assistant to Find Matched Patterns
https://forums.ni.com/t5/Archive-TKB/Use-Vision-Assistant-to-Find-Matched-Patterns/ta-p/3523169
Pool Playing Robot
https://forums.ni.com/t5/Student-Projects/Pool-Playing-Robot/ta-p/3528474
EDIT: added more examples
Robert P-F
(3,108 Views)
