IMAQ usb Camera black screen in exe file
USB Camera works in vi file. In the exe file but the screen is black. I tried other solutions posted in the forum. There are those who wrote that it was fixed when repaired. I tried again it didn't work. Then I completely uninstalled labview. I reinstalled. It still didn't work. How can I find a solution?
Thanks for help
Message 1 of 12
(3,501 Views)
Hi Melli,
do you get any errors in your executable from IMAQ?
When the image display stays black then there should be an error…
AFAIK you need runtime licenses to use IMAQ/Vision functions in executables: can this be an error source in your case? (I'm not sure about that as I don't work with IMAQ.)
Message 2 of 12
(3,496 Views)
There is no errors. Just black screen.
I checked licenses. It is okey.
I tried it when I took labview lesson. I saw it working. But now I'm stuck in my undergraduate project.
Message 3 of 12
(3,493 Views)
Hi Melli,
do you even check for errors in your executable? Is there some error logging in your program implemented?
(One more idea: Did you verify the correct camera references is used in the executable?)
Message 4 of 12
(3,483 Views)
Hi, GerdW
I put error box. There was not error. The interesting thing is the camera works in vi.
I think it's a firewall issue. Do you think this could be the problem? If it is firewall problem, how can I solve?
Message 5 of 12
(3,453 Views)
Hi Melli,
Maybe a firewall interferes network communication of your executable…
To solve that you need to check the firewall settings/parameters/rules!
Message 6 of 12
(3,450 Views)
I checked the firewall. Exe file is allowed. I did it once. There was no problem. Why is this happening? How can I find a problem?
Message 7 of 12
(3,427 Views)
Hi Melli,
Then you need to debug your code.
As you did not provide any attachments so far you need to do that on your own!
When the executable only "shows a black image" then I see two options:
  • there is an error when IMAQ is called, resulting in a black IMAQ indicator
  • there is no error when calling the IMAQ functions: in this case the camera actually delivers "just a black" image. (Does your executable set any camera properties in a weird way?)
In the end it sums up to "Debug your code"…
Message 8 of 12
(3,421 Views)
I have had this problem before. The quick fix was to manually install the vision runtime engine. There is a kowledgebase for this but I can't find it now.
https://www.ni.com/en-gb/support/downloads/software-products/download.vision-development-module-runt...
Message 9 of 12
(3,418 Views)
Accepted by topic author MelliCain
In the EXE build settings, there is check box called "Allow future versions of the LabVIEW Runtime to run this application".  Try turning that off.
Message 10 of 12
(3,414 Views)
