IMAQ write palette not visible
I have installed NI Vision 2011 but IMAQ write file vi is not visible but IMAQ write file 2 vi is visible. No idea what is the problem.
I am using labview 2011 on windows 7.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,697 Views)
Write2 replaces Write.  It handles file formats differently.  I believe there is a legacy option during install that will put these earlier versions of Vision VIs into a separate folder, if needed.  Check the Device Drivers Install CD, and DVD 2.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(2,668 Views)
Yes I can manage the same thing using file 2 also.
--Ranjeet
(2,657 Views)
