IMAQdx Get Image Error Code-1074360293
Hi all
After making a quick fix to my program which has since been removed, I found the above error code had been introduced.
Previously it was not a problem and on another computer/camera set up it is also running correctly.
Just wondering if someone can explain exactly what the error code means, if it is always a timeout issue or if it is used by labview as a "catch all" error code for other issues as well
GD
(4,323 Views)
It's the "almost catch all" error if you have any problems with the acquistion from a camera.
So what was this "quick fix" which introduced the error? What kind of camera and interface are you using?
Christian
(4,319 Views)
The quick fix was to trigger from an ANPR camera instead of a context camera within the system, unfortunately it needs to be triggered from context camera as a lot of the automation comes from processing the context image.
The cameras we are using are xenics.
I'm afraid I'm very limited as to how much information I can provide/ask for because of a NDA with the company
GD
(4,315 Views)
I'm not able to follow you with the "context camera".
Anyhow, if you are waiting for a trigger and you get an timeout you might want to have a closer look at the trigger signal.
Christian
(4,311 Views)
Hi GD,
Just wondering if you had any progress removing this "catch-all" error from your IMAQ application? Have you tried reverting to your original working code (prior to triggering from the ANPR) to see if the error still appears?
Any further details regarding the issue you are experiencing will be appreciated.
Many Thanks
Jamie S.
(4,300 Views)
