IMAQdx installed but not in palette
Hi all,
I have made sure to activate IMAQdx. The license manager and MAX both confirm that it was installed.
However, I can't see any of the IMAQdx in my palette, although the existing IMAQdx subVIs in my diagram were successfully found and executing properly.
Do I need to manually show the palette where IMAQdx is installed locally?
Thanks!
(2,693 Views)
You probably need to configure the Block Diagram "gadget" to show Vision and Motion VIs (by default, only a particular subset of VIs, presumably those NI thinks are the best "default" choice) are visible.  To "adjust" this:
  • Open any Block Diagram (even a blank one).
  • Right-click on the Diagram to bring up the Functions Palette.  Check that Vision and Motion are not showing.
  • Click the Pin in the upper left corner of the Palette to "pin" the Palette to the Block Diagram.
  • Click the "Customize" option, and choose "Change Visible Palettes".
  • Check the box next to Vision and Motion.  You can further customize the Palettes as you wish.
  • To finish, just close (upper right-hand corner) the pinned Palette.  You should now see Vision and Motion.
Bob Schor
(2,662 Views)
