IMAQdx not being installed properly
hi all, when i try to install IMAQdx on my pc,i get the following messages. "Error 133. The cabinet file "niimaq.cab" required for this installation is corrupt.This could indicate network error, an error reading from the CD-ROM, or a problem with this package." When I ignore this, here comes the next which says "The NI IMAQ 4.4 installation has failed with following error.Internal error 2350.Continue?" Please help me in this regard. many thanks.
(2,394 Views)
Not sure what the problem is, what other NI software do you have on that computer?
You can check this page to learn about compatibility and also maybe you can download the latest VAS installer form here.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,393 Views)
