IMC for PID
Hello everyone,
I have a second order system which i am controlling with a PID controller. My question is, how could i define IMC (Internal Model Control) parameters to control the system? I have seen there is an example but i don't understand how it works. Any ideas?
(3,367 Views)
Perhaps if you linked the example we could try and explain how it works. However, if the question is "How do I determine PID gain coefficients to control my system" then likely the answer will be very generic, or you will need to give more information about your system.
GCentral
(3,306 Views)
Hello sorry for my late response,
actually yes I want to define the PID gains for my system in order to have IMC control. That's why I was checking this particular example which seems to do so. I attach both my system and the example and hope for some help.
(3,272 Views)
Actually, i know that my system has an unstable pole that needs to be changed, i am not sure about zeros. And the problem is how i define the other model needed in order to have IMC control. I would be glad to here some advices.
(3,246 Views)
